Einleitung
This is how you remove the bottom cover
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Remove the expansion pack cover by pushing in the tab and pulling out.
Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
Remove the metal plate indicated in the example by sliding it back and then lifting it up.
Remove the two screws indicated in the example using the smaller Phillips screwdriver.
Remove the screw to the right of the LED light using the larger Phillips screwdriver.
Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
Remove the seven screws indicated in the example using the larger Phillips screwdriver.
Remove the four screws indicated using the #1 Phillips screwdriver.
Remove everything from the bottom cover.
11 weitere Nutzer haben diese Anleitung absolviert.
