Zum Hauptinhalt wechseln
Nintendo 64 Metal Plate Replacement
Was du brauchst
  1. Nintendo 64 Metal Plate Replacement, Top Cover: Schritt 1, Bild 1 von 1
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Metal Plate Replacement: Schritt 2, Bild 1 von 1
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Metal Plate Replacement: Schritt 3, Bild 1 von 1
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Metal Plate Replacement: Schritt 4, Bild 1 von 1
    • Remove the two front feet of the N64.
  5. Nintendo 64 Metal Plate Replacement: Schritt 5, Bild 1 von 1
    • Rotate to top side up and lift off top cover.
  6. Nintendo 64 Metal Plate Replacement, Metal Plate: Schritt 6, Bild 1 von 2 Nintendo 64 Metal Plate Replacement, Metal Plate: Schritt 6, Bild 2 von 2
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  7. Nintendo 64 Metal Plate Replacement: Schritt 7, Bild 1 von 2 Nintendo 64 Metal Plate Replacement: Schritt 7, Bild 2 von 2
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Nintendo 64 Metal Plate Replacement: Schritt 8, Bild 1 von 1
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Nintendo 64 Metal Plate Replacement: Schritt 9, Bild 1 von 1
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Nintendo 64 Metal Plate Replacement: Schritt 10, Bild 1 von 1
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Nintendo 64 Metal Plate Replacement: Schritt 11, Bild 1 von 2 Nintendo 64 Metal Plate Replacement: Schritt 11, Bild 2 von 2
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  12. Nintendo 64 Metal Plate Replacement: Schritt 12, Bild 1 von 2 Nintendo 64 Metal Plate Replacement: Schritt 12, Bild 2 von 2
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Nintendo 64 Metal Plate Replacement: Schritt 13, Bild 1 von 2 Nintendo 64 Metal Plate Replacement: Schritt 13, Bild 2 von 2
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  14. Nintendo 64 Metal Plate Replacement: Schritt 14, Bild 1 von 1
    • Lift off and remove the metal plate as indicated in the example.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
LisaF818
143 Reputation
1 Anleitung geschrieben
Cal Poly, Team 5-4, Regan Fall 2009 Mitglied von Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 11,037
