Zum Hauptinhalt wechseln
Nintendo DS Lite Battery Replacement
Was du brauchst
  1. Nintendo DS Lite Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Nintendo DS Lite Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Nintendo DS Lite Battery Replacement: Schritt 2, Bild 1 von 1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
Abschluss
46 weitere Nutzer:innen haben diese Anleitung absolviert.
Matthew Newsom
39.500 Reputation
67 Anleitungen geschrieben
5 Kommentare
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - Antwort
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - Antwort
Thanks but will a dsi battery work
Zach - Antwort
My battery cover won’t come off.
Jake - Antwort
Flip the console upside down and it will but don’t pull it will break hold it close to the console then slide it back
dead -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 30
Letzte 7 Tage: 202
Letzte 30 Tage: 942
Insgesamt: 53,333
