Zum Hauptinhalt wechseln
Nintendo DS Lite Shoulder Buttons Replacement
Was du brauchst
  1. Nintendo DS Lite Shoulder Buttons Replacement, Remove the battery cover: Schritt 1, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
  2. Nintendo DS Lite Shoulder Buttons Replacement, Remove the lower case: Schritt 2, Bild 1 von 1
    • Use a spudger to pry out the battery.
    • Pry off the rubber feet.
    • Remove the seven screws securing the lower case:
    • Three tri-wing screws
    • One Phillips screw
    • Two gold Phillips screws
    • One black tri-wing screw
  3. Nintendo DS Lite Shoulder Buttons Replacement: Schritt 3, Bild 1 von 1
    • Carefully pry the bottom cover off.
    • Remove the shoulder buttons by pulling out the metal pegs that secure them to DS.
    • The triggers are held in by tiny metal pegs and springs. Keep track of each piece.
  4. Nintendo DS Lite Shoulder Buttons Replacement: Schritt 4, Bild 1 von 3 Nintendo DS Lite Shoulder Buttons Replacement: Schritt 4, Bild 2 von 3 Nintendo DS Lite Shoulder Buttons Replacement: Schritt 4, Bild 3 von 3
    • You can now access the micro-button component and replace or repair anything as needed.
Abschluss
To reassemble your device, follow the steps in reverse order after making your repair.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
For anyone dealing with unresponsive shoulder buttons, I highly recommend watching this video guide;
https://www.youtube.com/watch?v=VnWdawXC...
Gabriel Branyiczky - Antwort
たしかにそうですね!!!
kawagoe -
とても、わかりやすくて、しっかり修理できました!
kawagoe - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 44
Letzte 30 Tage: 203
Insgesamt: 5,211
