Einleitung
This guide will explain how to replace the shoulder buttons on a DS Lite if they are sticking or not working properly.
The tools you’ll need for this task are:
- Spudger or other flat tool
- Screwdrivers
- Phillips
- Tri-wing
Was du brauchst
Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
Use a spudger to pry out the battery.
Pry off the rubber feet.
Remove the seven screws securing the lower case:
Three tri-wing screws
One Phillips screw
Two gold Phillips screws
One black tri-wing screw
Carefully pry the bottom cover off.
Remove the shoulder buttons by pulling out the metal pegs that secure them to DS.
You can now access the micro-button component and replace or repair anything as needed.
To reassemble your device, follow the steps in reverse order after making your repair.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
For anyone dealing with unresponsive shoulder buttons, I highly recommend watching this video guide;
https://www.youtube.com/watch?v=VnWdawXC...
たしかにそうですね!!!
kawagoe -
