Einleitung
Replacing your DSi's battery only requires a Phillips #00 screwdriver and a thin prying tool.
Was du brauchst
Unscrew the two Phillips screws securing the battery cover to the lower case.
Grasp the battery cover and lift it out of the lower case.
Using a spudger tool (or your fingernail), lift up the battery from the top.
Grasp the battery and remove it from the DSi.
19 weitere Nutzer:innen haben diese Anleitung absolviert.
