Zum Hauptinhalt wechseln
Nintendo DSi Touch Screen / Bottom LCD Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Achtung: Die Schritte 1-2 stammen von einer Anleitung, die derzeit bearbeitet wird.
    Nintendo DSi Touch Screen / Bottom LCD Replacement, Battery: Schritt 1, Bild 1 von 1
    • Loosen the two screws on the battery panel. Then lift the panel up to remove it.
  2. Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 2, Bild 1 von 1
    • L Button.
    • Top of the battery pack.
    • To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
  3. Nintendo DSi Touch Screen / Bottom LCD Replacement, Lower Case Assembly: Schritt 3, Bild 1 von 2 Nintendo DSi Touch Screen / Bottom LCD Replacement, Lower Case Assembly: Schritt 3, Bild 2 von 2
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
  4. Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 4, Bild 1 von 1
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
  5. Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 5, Bild 1 von 3 Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 5, Bild 2 von 3 Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 5, Bild 3 von 3
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 6, Bild 1 von 2 Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 6, Bild 2 von 2
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
  7. Nintendo DSi Touch Screen / Bottom LCD Replacement, Wi-Fi Board: Schritt 7, Bild 1 von 1
    • Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
  8. Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 8, Bild 1 von 1
    • Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
  9. Achtung: Die Schritte 9-10 stammen von einer Anleitung, die derzeit bearbeitet wird.
    Nintendo DSi Touch Screen / Bottom LCD Replacement, Disconnecting Nintendo DSi Battery Board: Schritt 9, Bild 1 von 1
    • Flip up the black latch and disconnect the D-Pad/Power Button ribbon cable.
  10. Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 10, Bild 1 von 3 Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 10, Bild 2 von 3 Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 10, Bild 3 von 3
    • The power connector (with red and black wires) is difficult to remove without damaging it, unless you take a moment and understand how it works. Look at all of the photos for this step before continuing.
    • The connector is two pieces -- a white "male" piece (connected to the wires), and a beige "female" part (soldered to the main board).
    • There is a small "notch" in the female part, to give you a place to insert a small flat-head screwdriver. Put the corner of your screwdriver in there, and twist it gently to push the white part up (away from the main board). Do not try to pull it to the right (towards the battery board).
    • If it does not lift easily, try again with a smaller screwdriver. You might be pulling the female connector off the board, which will be difficult to repair.
  11. Nintendo DSi Touch Screen / Bottom LCD Replacement, Disconnecting (Top) Nintendo DSi Motherboard cables: Schritt 11, Bild 1 von 2 Nintendo DSi Touch Screen / Bottom LCD Replacement, Disconnecting (Top) Nintendo DSi Motherboard cables: Schritt 11, Bild 2 von 2
    • If you have not already done so, disconnect the two bottom-LCD ribbon cables from the main board by prying up the black latches and pulling the cable out to the side.
    • The ribbon cable (marked in blue) for the touch screen is particularly thin and fragile; be careful to avoid bending it more than necessary.
    • Flip up the latch and remove the touch screen cable.
    • Flip up the latch and remove the top-screen ribbon cable.
    • Pry up on the orange cable to disconnect it from the main board, much like the antenna cable on the Wi-Fi module.
    • Do not pull on the orange cable that connects to the bottom of the motherboard.
  12. Nintendo DSi Touch Screen / Bottom LCD Replacement, Touch Screen / Bottom LCD: Schritt 12, Bild 1 von 2 Nintendo DSi Touch Screen / Bottom LCD Replacement, Touch Screen / Bottom LCD: Schritt 12, Bild 2 von 2
    • Remove 4 Phillips screws from the board.
    • Lift the main board from the bottom end and flip it over to reveal the last connector.
    • Keep the main board fairly close to the case, making sure not to damage the last ribbon cable holding it in place.
  13. Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 13, Bild 1 von 1
    • Reach under the front of the device, and push the bottom screen towards you, out of the frame.
  14. Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 14, Bild 1 von 1
    • If you are replacing the LCD, make a mark on the back of the bad LCD so you know which one is the good one; it is easy to confuse them and you can't test them without reassembling most of the unit.
  15. Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 15, Bild 1 von 2 Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 15, Bild 2 von 2
    • The bottom LCD assembly is actually two pieces which are glued together; if you replace one, you need to keep the working part and use it with the new part.
    • Carefully separate the two pieces by inserting a spudger into the groove between the metal piece and the darker piece, then pry them apart.
    • Set aside the broken piece; you should now have one working touch screen and one working bottom LCD, as two separate pieces.
  16. Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 16, Bild 1 von 1
    • It is important that the touch screen and LCD sit perfectly flat in the frame, or else you will not be able to close up the device. Putting the touch screen in the frame first helps accomplish this goal.
    • Lay the working touch screen down into the frame from the back side, with the ribbon cable oriented as shown.
  17. Nintendo DSi Touch Screen / Bottom LCD Replacement: Schritt 17, Bild 1 von 1
    • Place the LCD on top of the touch screen, with the two ribbon cables pointing towards the battery board (as shown in the picture).
    • Make sure that the edge of the LCD is flush with the black plastic frame, or you will not be able to reassemble the unit.
    • Make sure that both the white and pink cables are tucked into the "groove" formed by small plastic pegs; they must not overlap the screw threads or the buttons, or you may damage them while reassembling the device.
Abschluss
bushing
10.247 Reputation
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 6,313
