Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Use this guide to replace your DSi's single Wi-Fi antenna.
  1. Unscrew the two Phillips screws securing the battery cover to the lower case. The screws remain captive to the battery cover.
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift out of the lower case.
  2. Wedge the edge of a spudger in between the top of the battery and its lower case housing and pry upwards to dislodge the battery. Grasp the battery and remove it from the DSi.
    • Wedge the edge of a spudger in between the top of the battery and its lower case housing and pry upwards to dislodge the battery.
    • Grasp the battery and remove it from the DSi.
  3. Two screws are hidden underneath two rubber feet highlighted in red. Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
  4. Remove the following screws securing the lower case to the body of the DSi:
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
  5. Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi. Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing. Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Carefully lift the lower casing from its bottom edge. The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
  7. Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
    • Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
  8. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  9. Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
    • Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
  10. Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
    • Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
  11. Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets: Lower touchscreen cable
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets:
    • Lower touchscreen cable
    • Lower LCD cable
    • Power board cable
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • After flipping up the locking tabs on all three sockets, use your fingers or a pair of tweezers to gently pull the cables straight out of their sockets.
  12. Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap. Make sure you are flipping up the retaining flap, not the socket itself.
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
  13. Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap. Make sure you are flipping up the retaining flap, not the socket itself.
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap.
    • Use the tip of a spudger to pull the dual camera ribbon cable straight out of its socket.
  14. With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
    • With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
  15. Remove the following four Phillips screws securing the motherboard to the DSi framework.
    • Remove the following four Phillips screws securing the motherboard to the DSi framework.
    • Three longer screws.
    • One short screw.
    • Pull the microphone and Wi-Fi antenna cables out of the notch cut into the motherboard near the headphone jack.
  16. Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons . Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap. Make sure you are flipping up the retaining flap, not the socket itself.
    • Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons .
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap.
    • Remove the motherboard from the DSi.
  17. Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework. Lift the lower LCD assembly out of the DSi.
    • Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework.
    • Lift the lower LCD assembly out of the DSi.
  18. Use a pushpin to remove the four plastic screw covers (highlighted in red) on the front bezel. Use a pushpin to remove the four plastic screw covers (highlighted in red) on the front bezel.
    • Use a pushpin to remove the four plastic screw covers (highlighted in red) on the front bezel.
  19. Remove the four Phillips screws securing the rear bezel to the front bezel.
    • Remove the four Phillips screws securing the rear bezel to the front bezel.
  20. Using two hands, gently slide the rear bezel upwards. The rear bezel will move only about 2 mm. Lift the rear bezel straight up out of the DSi.
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
    • Lift the rear bezel straight up out of the DSi.
  21. De-route the Wi-Fi antenna cable from its slot in the bottom front bezel.
    • De-route the Wi-Fi antenna cable from its slot in the bottom front bezel.
  22. Lift the Wi-Fi board off its mounting posts on the top front bezel. De-route the Wi-Fi antenna cable through the hinge and remove it from the DSi.
    • Lift the Wi-Fi board off its mounting posts on the top front bezel.
    • De-route the Wi-Fi antenna cable through the hinge and remove it from the DSi.
Abschluss
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 2
Letzten 30 Tage: 16
Insgesamt: 7,670
