Zum Hauptinhalt wechseln
Nintendo DSi XL Lower Case Replacement
Was du brauchst
  1. Nintendo DSi XL Lower Case Replacement, Battery: Schritt 1, Bild 1 von 2 Nintendo DSi XL Lower Case Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Lower Case Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Lower Case Replacement, Lower Case: Schritt 3, Bild 1 von 3 Nintendo DSi XL Lower Case Replacement, Lower Case: Schritt 3, Bild 2 von 3 Nintendo DSi XL Lower Case Replacement, Lower Case: Schritt 3, Bild 3 von 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Lower Case Replacement: Schritt 4, Bild 1 von 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Lower Case Replacement: Schritt 5, Bild 1 von 3 Nintendo DSi XL Lower Case Replacement: Schritt 5, Bild 2 von 3 Nintendo DSi XL Lower Case Replacement: Schritt 5, Bild 3 von 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Lower Case Replacement: Schritt 6, Bild 1 von 2 Nintendo DSi XL Lower Case Replacement: Schritt 6, Bild 2 von 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Lower Case Replacement: Schritt 7, Bild 1 von 2 Nintendo DSi XL Lower Case Replacement: Schritt 7, Bild 2 von 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
David Hodson
152.623 Reputation
127 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 21
Letzte 30 Tage: 77
Insgesamt: 9,405
