Einleitung
Be the envy of onlooking gamers with a shiny new rear bezel on your DSi XL.
Was du brauchst
Use a push pin to remove the four plastic screw covers on the front bezel.
Insert a spudger into the gap between the front and rear bezel
Rotate the spudger away from the DSi XL, prying the two bezels apart.
In the same manner as described above, continue prying along the top edge of the front and rear bezels.
Use the flat end of a spudger to pry the rear camera off the rear bezel.
Remove the rear bezel.
3 weitere Personen haben diese Anleitung absolviert.
