Einleitung
If your controllers are not broken but are not working, then you should replace the controller outlets. Follow our guide for further information.
Was du brauchst
Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
Remove the seven 13.25mm Phillips screws from the metal cover with a Phillips head #2 screwdriver.
Remove the metal cover by pulling it up and away from the rest of the console with your hands.
Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
Note: Underneath the cartridge tray is a black trapezoid-shaped tab/lip (see marker). When properly assembled this tab/lip goes below the motherboard and shielding as seen here.
Remove the three 13.25mm Phillips screws that secure the motherboard to the lower case with a Phillips head #2 screwdriver.
Pull the motherboard assembly straight up and out of the plastic case with your hands.
Disconnect the wire harnesses from the motherboard assembly:
Player 1
Player 2
Power
Remove the two 7.6mm Phillips screws that secure the plastic controller outlet cover with a Phillips head #2 screwdriver.
Pull the plastic cover off of the plastic NES case with your hands.
Pull the controller outlet straight out with your hands, leaving an open hole in the plastic NES case.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
