Zum Hauptinhalt wechseln
Nintendo Game Boy Advance SP Battery Replacement
Was du brauchst
  1. Nintendo Game Boy Advance SP Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Battery Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Battery Replacement: Schritt 3, Bild 1 von 1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
Abschluss
For reassembly, follow the instructions in reverse order.
30 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 17-22, Forte Winter 2013 Mitglied von Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Mitglieder
39 Anleitungen geschrieben
2 Kommentare
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
Santi12008 - Antwort
Thanks for yout guideline. I settle in 5 minutes.
aam9999 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 18
Letzte 7 Tage: 213
Letzte 30 Tage: 1,049
Insgesamt: 64,779
