Einleitung
The brightness switch is the circular button with a sun symbol engraved into it. The brightness switch is located at the top of the button panel.
Was du brauchst
Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
Use your fingers or a plastic opening tool to remove the battery from the device.
Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
Flip the motherboard up and rest it on the other half of the device, so that the back of the buttons are visible as seen in the picture.
With your fingers, lift the track pad out off the brightness switch.
Using tweezers, lift the brightness switch out of the Game Boy Advance SP.
15 weitere Personen haben diese Anleitung absolviert.
