Zum Hauptinhalt wechseln
Nintendo Game Boy Advance SP Speaker Replacement
Was du brauchst
  1. Nintendo Game Boy Advance SP Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Speaker Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Speaker Replacement: Schritt 3, Bild 1 von 1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Speaker Replacement, Back Cover: Schritt 4, Bild 1 von 2 Nintendo Game Boy Advance SP Speaker Replacement, Back Cover: Schritt 4, Bild 2 von 2
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Speaker Replacement: Schritt 5, Bild 1 von 1
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Speaker Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
  7. Nintendo Game Boy Advance SP Speaker Replacement: Schritt 7, Bild 1 von 1
    • Be careful not to tear the ribbon cable that's connected to the screen. If you tear it, games will not appear on the device's screen!
    • Flip the motherboard up and rest it on the other half of the device, so that the back of the buttons are visible as seen in the picture.
  8. Nintendo Game Boy Advance SP Speaker Replacement, Speaker: Schritt 8, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Lift the speaker out of its slot in the button panel, using a plastic opening tool or tweezers.
    • Leave the foam circle inside the speaker's slot in the button panel. It keeps the speaker from moving and improves sound quality.
Abschluss
13 weitere Personen haben diese Anleitung absolviert.
DJ Pantone
1.938 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 17-22, Forte Winter 2013 Mitglied von Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Mitglieder
41 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 49
Letzte 30 Tage: 171
Insgesamt: 21,140
