Einleitung
This guide will demonstrate proper removal of the D-Pad. This is necessary in order to clean or replace it.
Was du brauchst
Place the controller (buttons down) on a solid surface.
Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
Grab the Z-button by the peg with tweezers and lift it out of the controller.
Use tweezers to grab the center peg of the directional pad and lift it out of its socket.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
