Zum Hauptinhalt wechseln
Nintendo NES Advantage A Button Replacement
Was du brauchst
  1. Nintendo NES Advantage A Button Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the four sticky pads from the bottom of the device.
    • If the pads are stuck, use a spudger to remove them.
  2. Nintendo NES Advantage A Button Replacement: Schritt 2, Bild 1 von 2 Nintendo NES Advantage A Button Replacement: Schritt 2, Bild 2 von 2
    • Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
    • Use your hands to pull the back panel away from the controller.
  3. Nintendo NES Advantage A Button Replacement, Circuit Board: Schritt 3, Bild 1 von 2 Nintendo NES Advantage A Button Replacement, Circuit Board: Schritt 3, Bild 2 von 2
    • Remove the three 14 mm screws from the gray cross with a Phillips #0 screwdriver.
    • Lift the gray component away from the device.
  4. Nintendo NES Advantage A Button Replacement: Schritt 4, Bild 1 von 1
    • Lift up the black wire and move it to the side.
  5. Nintendo NES Advantage A Button Replacement: Schritt 5, Bild 1 von 3 Nintendo NES Advantage A Button Replacement: Schritt 5, Bild 2 von 3 Nintendo NES Advantage A Button Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the two silver knobs on the front of the device.
    • Unscrew the two silver nuts using a flathead screwdriver.
    • Remove each silver nut and silver washer using a pair of tweezers.
  6. Nintendo NES Advantage A Button Replacement: Schritt 6, Bild 1 von 2 Nintendo NES Advantage A Button Replacement: Schritt 6, Bild 2 von 2
    • Remove the remaining three 8 mm screws on the circuit board with a Phillips #0 screwdriver.
    • Remove the silver bracket from the top of the circuit board.
  7. Nintendo NES Advantage A Button Replacement: Schritt 7, Bild 1 von 1
    • Remove the circuit board from the controller.
  8. Nintendo NES Advantage A Button Replacement, A Button: Schritt 8, Bild 1 von 1
    • Remove the A Button from the case.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 335
