Einleitung
Are you experiencing trouble with your controller not working? This may contribute to the system not recognizing the controller input or a broken controller port. With this guide, we will help you replace the port in efforts to fix this problem. You will need a 4.5mm Gamebit screwdriver and a 1.25mm white ribbon cable for this guide as well. Happy fixing!
Was du brauchst
Remove the six 13.5 mm screws on the lower case with a 4.5 mm Gamebit screwdriver.
Carefully disconnect the ribbon cable that is attached to the controller board and the main board.
Disconnect and remove the old cable and replace it with a new 1.25 mm ribbon cable.
