Einleitung
Whether or not you need to replace the upper case of your device or simply needing to know how to remove the top covering of your Super Famicon, this guide will provide the steps to doing so. You will only need a Gamebit screwdriver. Happy Fixing!
Was du brauchst
Remove the six 13.5 mm screws on the lower case with a 4.5 mm Gamebit screwdriver.
Fast fertig!
Abschluss
