Zum Hauptinhalt wechseln
Nintendo Switch 2 Button Board Replacement
Was du brauchst
  1. Nintendo Switch 2 Button Board Replacement, Power off the console: Schritt 1, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Power off the console: Schritt 1, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Power off the console: Schritt 1, Bild 3 von 3
    • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
    • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
    • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
  2. Nintendo Switch 2 Button Board Replacement, Remove the bottom screws: Schritt 2, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Remove the bottom screws: Schritt 2, Bild 2 von 2
    • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
    • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
  3. Nintendo Switch 2 Button Board Replacement, Remove the top screw: Schritt 3, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Remove the top screw: Schritt 3, Bild 2 von 2
    • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
  4. Nintendo Switch 2 Button Board Replacement, Heat the right side sticker: Schritt 4, Bild 1 von 1
    • The Switch 2 has stickers on either side that need to removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
    • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
    • You can use the kickstand to prop the console up vertically for easier access.
    • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
  5. Nintendo Switch 2 Button Board Replacement, Pry up the right side sticker: Schritt 5, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Pry up the right side sticker: Schritt 5, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Pry up the right side sticker: Schritt 5, Bild 3 von 3
    • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
    • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
    • Gently pry up on the sticker until it starts to lift from the console.
    • Leave the tweezers in place to keep the sticker lifted.
  6. Nintendo Switch 2 Button Board Replacement: Schritt 6, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement: Schritt 6, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Jimmy
    $7.95
    • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
    • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
    • Remove the tweezers once the sticker is lifted.
    • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
  7. Nintendo Switch 2 Button Board Replacement, Heat the right side sticker: Schritt 7, Bild 1 von 1
    • Reheat the bottom of the right side until it's hot to the touch.
  8. Nintendo Switch 2 Button Board Replacement, Remove the right side sticker: Schritt 8, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Remove the right side sticker: Schritt 8, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Remove the right side sticker: Schritt 8, Bild 3 von 3
    • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
  9. Nintendo Switch 2 Button Board Replacement, Remove the left side sticker: Schritt 9, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Remove the left side sticker: Schritt 9, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Remove the left side sticker: Schritt 9, Bild 3 von 3
    • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
  10. Nintendo Switch 2 Button Board Replacement, Remove the side screws: Schritt 10, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Remove the side screws: Schritt 10, Bild 2 von 2
    • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
  11. Nintendo Switch 2 Button Board Replacement, Open the kickstand: Schritt 11, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Open the kickstand: Schritt 11, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Open the kickstand: Schritt 11, Bild 3 von 3
    • Use your fingers to flip up the kickstand on the back of the console.
    • If there's a microSD Express card installed, remove it now before you continue to the next step.
  12. Nintendo Switch 2 Button Board Replacement, Remove the back-side screws: Schritt 12, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Remove the back-side screws: Schritt 12, Bild 2 von 2
    • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
  13. Nintendo Switch 2 Button Board Replacement, Insert an opening pick: Schritt 13, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Insert an opening pick: Schritt 13, Bild 2 von 2
    • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
  14. Nintendo Switch 2 Button Board Replacement: Schritt 14, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement: Schritt 14, Bild 2 von 2
    • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
  15. Nintendo Switch 2 Button Board Replacement, Insert a second opening pick: Schritt 15, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Insert a second opening pick: Schritt 15, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Insert a second opening pick: Schritt 15, Bild 3 von 3
    • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
  16. Nintendo Switch 2 Button Board Replacement: Schritt 16, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement: Schritt 16, Bild 2 von 2
    • Slide the first opening pick back to where it was first inserted.
  17. Nintendo Switch 2 Button Board Replacement, Remove the back cover: Schritt 17, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Remove the back cover: Schritt 17, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Remove the back cover: Schritt 17, Bild 3 von 3
    • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
    • Hold the console with two hands. Rest your thumbs on the opening picks.
    • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
  18. Nintendo Switch 2 Button Board Replacement: Schritt 18, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement: Schritt 18, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement: Schritt 18, Bild 3 von 3
    • Lift the back cover up from the bottom edge and remove it.
  19. Nintendo Switch 2 Button Board Replacement, Remove the lower antenna screws: Schritt 19, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Remove the lower antenna screws: Schritt 19, Bild 2 von 2
    • Use a JIS 00 driver to remove the three 4.4 mm‑long silver screws securing the lower antenna.
  20. Nintendo Switch 2 Button Board Replacement, Remove the lower antenna: Schritt 20, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Remove the lower antenna: Schritt 20, Bild 2 von 2
    • Use tweezers or your fingers to remove the lower antenna.
  21. Nintendo Switch 2 Button Board Replacement, Remove the upper antenna screws: Schritt 21, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Remove the upper antenna screws: Schritt 21, Bild 2 von 2
    • Use a JIS 00 driver to remove the two screws securing the upper antenna:
    • One 4.4 mm‑long silver screw
    • One 4.6 mm‑long green screw
  22. Nintendo Switch 2 Button Board Replacement, Remove the upper antenna: Schritt 22, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Remove the upper antenna: Schritt 22, Bild 2 von 2
    • Use tweezers or your fingers to remove the upper antenna.
  23. Nintendo Switch 2 Button Board Replacement, Disconnect the lower antenna cable: Schritt 23, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Disconnect the lower antenna cable: Schritt 23, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Disconnect the lower antenna cable: Schritt 23, Bild 3 von 3
    • Insert an arm of angled tweezers under the metal neck of the white interconnect cable coaxial connector (located beneath the lower antenna) and lift straight up to disconnect it.
  24. Nintendo Switch 2 Button Board Replacement, Disconnect the remaining antenna cables: Schritt 24, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Disconnect the remaining antenna cables: Schritt 24, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Disconnect the remaining antenna cables: Schritt 24, Bild 3 von 3
    • Repeat this procedure to disconnect the three central coaxial connectors from the board.
  25. Nintendo Switch 2 Button Board Replacement, Disconnect the MicroSD connector: Schritt 25, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Disconnect the MicroSD connector: Schritt 25, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Disconnect the MicroSD connector: Schritt 25, Bild 3 von 3
    • Use the flat end of a spudger to pry up and disconnect the MicroSD card reader press connector, located next to the bottom USB‑C port.
  26. Nintendo Switch 2 Button Board Replacement, Remove the shield plate screws: Schritt 26, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Remove the shield plate screws: Schritt 26, Bild 2 von 2
    • Use a JIS 00 driver to remove the seven screws securing the shield plate:
    • Two 6.2 mm‑long silver screws
    • Five 4.4 mm‑long silver screws
  27. Nintendo Switch 2 Button Board Replacement, Lift the shield plate: Schritt 27, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Lift the shield plate: Schritt 27, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Lift the shield plate: Schritt 27, Bild 3 von 3
    • Insert the flat end of a spudger between the shield plate and the processor's heat sink, next to the square (⛶) marking on the shield plate.
    • Twist the spudger to lift the shield plate and separate the thermal putty bonded to it. Keep lifting the shield plate until you don't feel resistance.
  28. Nintendo Switch 2 Button Board Replacement: Schritt 28, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement: Schritt 28, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement: Schritt 28, Bild 3 von 3
    • Lift the left edge of the shield plate to ensure it's fully separated from the thermal putty.
    • Gently set the shield plate back down.
  29. Nintendo Switch 2 Button Board Replacement, Unroute the gray antenna cable: Schritt 29, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Unroute the gray antenna cable: Schritt 29, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Unroute the gray antenna cable: Schritt 29, Bild 3 von 3
    • Insert one arm of angled tweezers underneath the gray antenna cable at the bottom-right corner of the console.
    • Lift the cable out of the black clip securing it to the frame.
  30. Nintendo Switch 2 Button Board Replacement: Schritt 30, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement: Schritt 30, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement: Schritt 30, Bild 3 von 3
    • Unroute the gray antenna cable from its channel along the right edge of the console.
  31. Nintendo Switch 2 Button Board Replacement: Schritt 31, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement: Schritt 31, Bild 2 von 2
    • Lift and slide the shield plate away from the right edge of the console until the gray antenna cable is completely free.
  32. Nintendo Switch 2 Button Board Replacement, Remove the shield plate: Schritt 32, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Remove the shield plate: Schritt 32, Bild 2 von 2
    • Pick up and remove the shield plate.
  33. Nintendo Switch 2 Button Board Replacement, Disconnect the battery: Schritt 33, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Disconnect the battery: Schritt 33, Bild 2 von 2
    • Insert the flat end of a spudger underneath the flat-topped battery connector, located next to the battery, and pry up to disconnect it.
  34. Nintendo Switch 2 Button Board Replacement, Clean the heat pipe: Schritt 34, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Clean the heat pipe: Schritt 34, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Clean the heat pipe: Schritt 34, Bild 3 von 3
    Arctic Silver ArctiClean
    $11.99
    • If you don't have replacement thermal putty, use the flat end of a spudger to distribute the old putty evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate, then skip this step.
    • Use the flat end of a spudger to scrape off the thermal putty on top of the copper heat pipe.
    • Apply high-concentration (90% or higher) isopropyl alcohol or thermal material remover to a cotton swab or lint-free cloth and wipe away any remaining thermal putty on both the heat pipe and shield plate.
    • Don't use a paper towel or rag, as they may scratch the shield plate.
  35. Nintendo Switch 2 Button Board Replacement, Disconnect the button board: Schritt 35, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Disconnect the button board: Schritt 35, Bild 2 von 2
    • Use the point of a spudger to flip up the locking flap on the button board cable ZIF connector, located next to the battery on the console's board.
  36. Nintendo Switch 2 Button Board Replacement: Schritt 36, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement: Schritt 36, Bild 2 von 2
    • Use tweezers or your fingers to gently pull the cable out of its connector.
  37. Nintendo Switch 2 Button Board Replacement, Free the button board cable: Schritt 37, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Free the button board cable: Schritt 37, Bild 2 von 2
    • Slide an opening pick underneath the button board cable to separate the adhesive securing it to the frame.
  38. Nintendo Switch 2 Button Board Replacement, Remove the button board: Schritt 38, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Remove the button board: Schritt 38, Bild 2 von 2
    • Lift the button board to remove it.
  39. Nintendo Switch 2 Button Board Replacement, Disassembly complete: Schritt 39, Bild 1 von 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
  40. Nintendo Switch 2 Button Board Replacement, Install the button board: Schritt 40, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Install the button board: Schritt 40, Bild 2 von 2
    • Set the button board into its slot, formed by several protruding pegs along the top of the frame.
  41. Nintendo Switch 2 Button Board Replacement, Route the button board cable: Schritt 41, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Route the button board cable: Schritt 41, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Route the button board cable: Schritt 41, Bild 3 von 3
    • Route the button board cable alongside the battery well.
    • Slide an opening pick across the length of the cable to adhere it to the battery well.
  42. Nintendo Switch 2 Button Board Replacement, Connect the button board: Schritt 42, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Connect the button board: Schritt 42, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Connect the button board: Schritt 42, Bild 3 von 3
    • Use tweezers or your fingers to insert the button board cable into its ZIF connector until it's fully seated.
    • If you're using tweezers, push on the cable's "wings" to ensure it's fully seated.
  43. Nintendo Switch 2 Button Board Replacement: Schritt 43, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement: Schritt 43, Bild 2 von 2
    • Use your finger or a spudger to flip the hinged locking flap down to secure the button board cable.
  44. Nintendo Switch 2 Button Board Replacement, Connect the battery: Schritt 44, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Connect the battery: Schritt 44, Bild 2 von 2
    • Align the battery connector over its socket on the board.
    • Use your finger or the flat end of a spudger to press the battery connector onto its socket until it's fully seated.
  45. Nintendo Switch 2 Button Board Replacement, Apply thermal putty: Schritt 45, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Apply thermal putty: Schritt 45, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Apply thermal putty: Schritt 45, Bild 3 von 3
    iFixit Thermal Putty
    $9.95
    • Apply a line of new thermal putty down the center of the heat pipe, roughly the thickness of a pea.
  46. Nintendo Switch 2 Button Board Replacement, Route the gray antenna cable: Schritt 46, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Route the gray antenna cable: Schritt 46, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Route the gray antenna cable: Schritt 46, Bild 3 von 3
    • Hold the top‑right corner of the shield plate above the top‑right corner of the console.
    • Route the gray antenna cable underneath the black hook near the top corner of the frame.
  47. Nintendo Switch 2 Button Board Replacement, Lower the shield plate: Schritt 47, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Lower the shield plate: Schritt 47, Bild 2 von 2
    • Lower the shield plate into place and align it with its screw holes.
  48. Nintendo Switch 2 Button Board Replacement, Finish routing the gray antenna cable: Schritt 48, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Finish routing the gray antenna cable: Schritt 48, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Finish routing the gray antenna cable: Schritt 48, Bild 3 von 3
    • Route the gray antenna cable down its channel on the right edge of the frame.
  49. Nintendo Switch 2 Button Board Replacement: Schritt 49, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement: Schritt 49, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement: Schritt 49, Bild 3 von 3
    • Press the gray antenna cable into its groove at the bottom of its channel, and continue routing until it's secured to the clip at the bottom of the frame.
  50. Nintendo Switch 2 Button Board Replacement, Install the shield plate screws: Schritt 50, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Install the shield plate screws: Schritt 50, Bild 2 von 2
    • Use a JIS 00 driver to install the seven screws securing the shield plate:
  51. Nintendo Switch 2 Button Board Replacement, Connect the MicroSD connector: Schritt 51, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Connect the MicroSD connector: Schritt 51, Bild 2 von 2
    • Use your finger or the flat end of a spudger to press the MicroSD card reader press connector onto its socket on the board.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  52. Nintendo Switch 2 Button Board Replacement, Connect the antenna cables: Schritt 52, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Connect the antenna cables: Schritt 52, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Connect the antenna cables: Schritt 52, Bild 3 von 3
    • Use tweezers to hold the lower antenna coaxial connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head instead of using more force.
    • Repeat this process to connect the three central coaxial connectors to their respective sockets.
    • The black cable connects to the socket closest to the fan, the white to the middle, and the gray the furthest away.
  53. Nintendo Switch 2 Button Board Replacement, Install the upper antenna: Schritt 53, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Install the upper antenna: Schritt 53, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Install the upper antenna: Schritt 53, Bild 3 von 3
    • Use tweezers or your fingers to align the upper antenna with its screw holes and black alignment pegs and set it into place.
    • Use a JIS 00 driver to install the two screws securing the upper antenna:
  54. Nintendo Switch 2 Button Board Replacement, Install the lower antenna: Schritt 54, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Install the lower antenna: Schritt 54, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Install the lower antenna: Schritt 54, Bild 3 von 3
    • Use tweezers or your fingers to align the lower antenna with its screw holes and gray alignment pegs and set it into place.
    • Use a JIS 00 driver to install the three 4.4 mm‑long screws securing the lower antenna.
  55. Nintendo Switch 2 Button Board Replacement, Prepare the back cover: Schritt 55, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Prepare the back cover: Schritt 55, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Prepare the back cover: Schritt 55, Bild 3 von 3
    • Fully pull out the game card tray.
    • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
    • Check the microphone to ensure it's fully seated in its slot in the frame.
  56. Nintendo Switch 2 Button Board Replacement, Install the back cover: Schritt 56, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Install the back cover: Schritt 56, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Install the back cover: Schritt 56, Bild 3 von 3
    • Align the top of the back cover with the top of the console.
    • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
    • Press along the top edge to fasten the clips securing the back cover to the console.
  57. Nintendo Switch 2 Button Board Replacement: Schritt 57, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement: Schritt 57, Bild 2 von 2
    • Squeeze the rest of the back cover and console together to fasten the clips.
  58. Nintendo Switch 2 Button Board Replacement, Install the back-side screws: Schritt 58, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Install the back-side screws: Schritt 58, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Install the back-side screws: Schritt 58, Bild 3 von 3
    • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
    • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
  59. Nintendo Switch 2 Button Board Replacement, Install the side screws: Schritt 59, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Install the side screws: Schritt 59, Bild 2 von 2
    • Install the two 3.6 mm‑long gold screws on each side of the console (four in total).
  60. Nintendo Switch 2 Button Board Replacement, Test the console: Schritt 60, Bild 1 von 2 Nintendo Switch 2 Button Board Replacement, Test the console: Schritt 60, Bild 2 von 2
    • Power on the console and test functionality to ensure it's working as expected.
  61. Nintendo Switch 2 Button Board Replacement, Install the stickers: Schritt 61, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement, Install the stickers: Schritt 61, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement, Install the stickers: Schritt 61, Bild 3 von 3
    • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
    • Set the sticker into its recess, first on one side, then the other.
    • Use your finger or the flat end of a spudger to press the sticker into place.
    • If the sticker isn't sticking well, apply heat after you press it into place.
  62. Nintendo Switch 2 Button Board Replacement: Schritt 62, Bild 1 von 3 Nintendo Switch 2 Button Board Replacement: Schritt 62, Bild 2 von 3 Nintendo Switch 2 Button Board Replacement: Schritt 62, Bild 3 von 3
    • Repeat this procedure to install the left side sticker.
Abschluss
You finished fixing your Switch 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
Nick Schultz
50.265 Reputation
288 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 30
Letzte 30 Tage: 97
Insgesamt: 549
