Zum Hauptinhalt wechseln
Nintendo Switch 2 Hinges Replacement
Was du brauchst
  1. Nintendo Switch 2 Hinges Replacement, Power off the console: Schritt 1, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Power off the console: Schritt 1, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Power off the console: Schritt 1, Bild 3 von 3
    • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
    • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
    • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
  2. Nintendo Switch 2 Hinges Replacement, Remove the bottom screws: Schritt 2, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement, Remove the bottom screws: Schritt 2, Bild 2 von 2
    • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
    • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
  3. Nintendo Switch 2 Hinges Replacement, Remove the top screw: Schritt 3, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement, Remove the top screw: Schritt 3, Bild 2 von 2
    • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
  4. Nintendo Switch 2 Hinges Replacement, Heat the right side sticker: Schritt 4, Bild 1 von 1
    • The Switch 2 has stickers on either side that need to removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
    • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
    • You can use the kickstand to prop the console up vertically for easier access.
    • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
  5. Nintendo Switch 2 Hinges Replacement, Pry up the right side sticker: Schritt 5, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Pry up the right side sticker: Schritt 5, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Pry up the right side sticker: Schritt 5, Bild 3 von 3
    • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
    • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
    • Gently pry up on the sticker until it starts to lift from the console.
    • Leave the tweezers in place to keep the sticker lifted.
  6. Nintendo Switch 2 Hinges Replacement: Schritt 6, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 6, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Jimmy
    $7.95
    • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
    • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
    • Remove the tweezers once the sticker is lifted.
    • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
  7. Nintendo Switch 2 Hinges Replacement, Heat the right side sticker: Schritt 7, Bild 1 von 1
    • Reheat the bottom of the right side until it's hot to the touch.
  8. Nintendo Switch 2 Hinges Replacement, Remove the right side sticker: Schritt 8, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Remove the right side sticker: Schritt 8, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Remove the right side sticker: Schritt 8, Bild 3 von 3
    • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
  9. Nintendo Switch 2 Hinges Replacement, Remove the left side sticker: Schritt 9, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Remove the left side sticker: Schritt 9, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Remove the left side sticker: Schritt 9, Bild 3 von 3
    • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
  10. Nintendo Switch 2 Hinges Replacement, Remove the side screws: Schritt 10, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement, Remove the side screws: Schritt 10, Bild 2 von 2
    • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
  11. Nintendo Switch 2 Hinges Replacement, Open the kickstand: Schritt 11, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Open the kickstand: Schritt 11, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Open the kickstand: Schritt 11, Bild 3 von 3
    • Use your fingers to flip up the kickstand on the back of the console.
    • If there's a microSD Express card installed, remove it now before you continue to the next step.
  12. Nintendo Switch 2 Hinges Replacement, Remove the back-side screws: Schritt 12, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement, Remove the back-side screws: Schritt 12, Bild 2 von 2
    • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
  13. Nintendo Switch 2 Hinges Replacement, Insert an opening pick: Schritt 13, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement, Insert an opening pick: Schritt 13, Bild 2 von 2
    • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
  14. Nintendo Switch 2 Hinges Replacement: Schritt 14, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement: Schritt 14, Bild 2 von 2
    • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
  15. Nintendo Switch 2 Hinges Replacement, Insert a second opening pick: Schritt 15, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Insert a second opening pick: Schritt 15, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Insert a second opening pick: Schritt 15, Bild 3 von 3
    • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
  16. Nintendo Switch 2 Hinges Replacement: Schritt 16, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement: Schritt 16, Bild 2 von 2
    • Slide the first opening pick back to where it was first inserted.
  17. Nintendo Switch 2 Hinges Replacement, Remove the back cover: Schritt 17, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Remove the back cover: Schritt 17, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Remove the back cover: Schritt 17, Bild 3 von 3
    • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
    • Hold the console with two hands. Rest your thumbs on the opening picks.
    • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
  18. Nintendo Switch 2 Hinges Replacement: Schritt 18, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 18, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 18, Bild 3 von 3
    • Lift the back cover up from the bottom edge and remove it.
  19. Nintendo Switch 2 Hinges Replacement, Remove the upper hinge covers: Schritt 19, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement, Remove the upper hinge covers: Schritt 19, Bild 2 von 2
    • Use the flat end of a spudger to pry up one of the hinge's plastic upper hinge covers until it "pops" up.
  20. Nintendo Switch 2 Hinges Replacement: Schritt 20, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement: Schritt 20, Bild 2 von 2
    • Pull the upper hinge cover out from underneath the lower hinge cover to remove it.
    • The cover is clipped in place and requires a little bit of force to remove.
  21. Nintendo Switch 2 Hinges Replacement: Schritt 21, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 21, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 21, Bild 3 von 3
    • Repeat this process to remove the upper hinge cover on the other hinge.
  22. Nintendo Switch 2 Hinges Replacement, Remove the kickstand screws: Schritt 22, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement, Remove the kickstand screws: Schritt 22, Bild 2 von 2
    • Use a JIS 00 driver to remove the two 2.3 mm‑long silver screws securing each hinge to the inside of the back cover (four total).
  23. Nintendo Switch 2 Hinges Replacement, Remove the kickstand: Schritt 23, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Remove the kickstand: Schritt 23, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Remove the kickstand: Schritt 23, Bild 3 von 3
    • Open the kickstand to a 45‑degree angle and pull it out of the back cover to remove it.
  24. Nintendo Switch 2 Hinges Replacement, Remove the hinge covers: Schritt 24, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement, Remove the hinge covers: Schritt 24, Bild 2 von 2
    • Use a JIS 00 driver to remove the 1.7 mm‑long black screw securing each hinge cover to the kickstand (two screws total).
  25. Nintendo Switch 2 Hinges Replacement: Schritt 25, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 25, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 25, Bild 3 von 3
    • Use your fingers to pull one of the hinge covers at a downward angle away from its hinge to remove it.
  26. Nintendo Switch 2 Hinges Replacement: Schritt 26, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 26, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 26, Bild 3 von 3
    • Repeat this process to pull the hinge cover off the other hinge.
  27. Nintendo Switch 2 Hinges Replacement, Fold the hinges: Schritt 27, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Fold the hinges: Schritt 27, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Fold the hinges: Schritt 27, Bild 3 von 3
    • Use your fingers to fold both hinges as far back as they'll go.
  28. Nintendo Switch 2 Hinges Replacement, Remove the hinge screws: Schritt 28, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement, Remove the hinge screws: Schritt 28, Bild 2 von 2
    • Use a JIS 00 driver to remove the two 2.3 mm‑long silver screws securing each hinge to the kickstand (four screws in total).
  29. Nintendo Switch 2 Hinges Replacement, Remove the hinges: Schritt 29, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Remove the hinges: Schritt 29, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Remove the hinges: Schritt 29, Bild 3 von 3
    • Lift one of the hinges off its alignment peg on the kickstand to remove it.
  30. Nintendo Switch 2 Hinges Replacement: Schritt 30, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 30, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 30, Bild 3 von 3
    • Repeat this process to remove the other hinge.
  31. Nintendo Switch 2 Hinges Replacement, Disassembly complete: Schritt 31, Bild 1 von 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
  32. Nintendo Switch 2 Hinges Replacement, Install the hinges: Schritt 32, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Install the hinges: Schritt 32, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Install the hinges: Schritt 32, Bild 3 von 3
    • Align one of the hinges with its alignment peg on the kickstand and set it into place.
    • Use a JIS 00 driver to install the two 2.3 mm‑long silver screws securing the hinge.
  33. Nintendo Switch 2 Hinges Replacement: Schritt 33, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 33, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 33, Bild 3 von 3
    • Align the other hinge with its alignment peg on the kickstand and set it into place.
  34. Nintendo Switch 2 Hinges Replacement, Open the hinges: Schritt 34, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement, Open the hinges: Schritt 34, Bild 2 von 2
    • Use your fingers to pull the hinges open until they're fully straight.
  35. Nintendo Switch 2 Hinges Replacement, Install the hinge covers: Schritt 35, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Install the hinge covers: Schritt 35, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Install the hinge covers: Schritt 35, Bild 3 von 3
    • Align one of the hinge covers with its respective hinge and press it into place.
  36. Nintendo Switch 2 Hinges Replacement: Schritt 36, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 36, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 36, Bild 3 von 3
    • Repeat this process for the other hinge cover.
  37. Nintendo Switch 2 Hinges Replacement: Schritt 37, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement: Schritt 37, Bild 2 von 2
    • Use a JIS 00 driver to install the 1.7 mm‑long black screw securing each hinge cover to the kickstand (two screws total).
  38. Nintendo Switch 2 Hinges Replacement, Install the kickstand: Schritt 38, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Install the kickstand: Schritt 38, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Install the kickstand: Schritt 38, Bild 3 von 3
    • Align the kickstand so its hinge covers are facing the back cover.
    • Insert the hinges through their slots in the back cover and set the kickstand into its cutout.
  39. Nintendo Switch 2 Hinges Replacement, Install the kickstand screws: Schritt 39, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement, Install the kickstand screws: Schritt 39, Bild 2 von 2
    • Use a JIS 00 driver to install the two 2.3 mm‑long silver screws securing each hinge to the inside of the back cover (four total).
  40. Nintendo Switch 2 Hinges Replacement, Install the upper hinge covers: Schritt 40, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Install the upper hinge covers: Schritt 40, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Install the upper hinge covers: Schritt 40, Bild 3 von 3
    • Align one of the upper hinge covers with its respective hinge, and slide it underneath the lower hinge cover.
    • Use your finger to press the upper hinge cover down until it clicks into place.
  41. Nintendo Switch 2 Hinges Replacement: Schritt 41, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 41, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 41, Bild 3 von 3
    • Repeat this process to install the other upper hinge cover.
  42. Nintendo Switch 2 Hinges Replacement, Prepare the back cover: Schritt 42, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Prepare the back cover: Schritt 42, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Prepare the back cover: Schritt 42, Bild 3 von 3
    • Fully pull out the game card tray.
    • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
    • Check the microphone to ensure it's fully seated in its slot in the frame.
  43. Nintendo Switch 2 Hinges Replacement, Install the back cover: Schritt 43, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Install the back cover: Schritt 43, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Install the back cover: Schritt 43, Bild 3 von 3
    • Align the top of the back cover with the top of the console.
    • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
    • Press along the top edge to fasten the clips securing the back cover to the console.
  44. Nintendo Switch 2 Hinges Replacement: Schritt 44, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement: Schritt 44, Bild 2 von 2
    • Squeeze the rest of the back cover and console together to fasten the clips.
  45. Nintendo Switch 2 Hinges Replacement, Install the back-side screws: Schritt 45, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Install the back-side screws: Schritt 45, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Install the back-side screws: Schritt 45, Bild 3 von 3
    • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
    • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
  46. Nintendo Switch 2 Hinges Replacement, Install the side screws: Schritt 46, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement, Install the side screws: Schritt 46, Bild 2 von 2
    • Install the two 3.6 mm‑long gold screws on each side of the console (four in total).
  47. Nintendo Switch 2 Hinges Replacement, Test the console: Schritt 47, Bild 1 von 2 Nintendo Switch 2 Hinges Replacement, Test the console: Schritt 47, Bild 2 von 2
    • Power on the console and test functionality to ensure it's working as expected.
  48. Nintendo Switch 2 Hinges Replacement, Install the stickers: Schritt 48, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement, Install the stickers: Schritt 48, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement, Install the stickers: Schritt 48, Bild 3 von 3
    • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
    • Set the sticker into its recess, first on one side, then the other.
    • Use your finger or the flat end of a spudger to press the sticker into place.
    • If the sticker isn't sticking well, apply heat after you press it into place.
  49. Nintendo Switch 2 Hinges Replacement: Schritt 49, Bild 1 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 49, Bild 2 von 3 Nintendo Switch 2 Hinges Replacement: Schritt 49, Bild 3 von 3
    • Repeat this procedure to install the left side sticker.
Abschluss
You finished fixing your Switch 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
Nick Schultz
50.356 Reputation
288 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 65
Insgesamt: 508
