Zum Hauptinhalt wechseln
Nintendo Switch Headphone Jack and Game Card Board Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Nintendo Switch Headphone Jack and Game Card Board Replacement, Release the Joy Con controller locking tabs: Schritt 1, Bild 1 von 3 Nintendo Switch Headphone Jack and Game Card Board Replacement, Release the Joy Con controller locking tabs: Schritt 1, Bild 2 von 3 Nintendo Switch Headphone Jack and Game Card Board Replacement, Release the Joy Con controller locking tabs: Schritt 1, Bild 3 von 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
    Frag FixBot
  2. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the Joy Con controllers: Schritt 2, Bild 1 von 3 Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the Joy Con controllers: Schritt 2, Bild 2 von 3 Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the Joy Con controllers: Schritt 2, Bild 3 von 3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
    Frag FixBot
  3. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the back-side screws: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
    • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
    • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
    Frag FixBot
  4. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the top and bottom screws: Schritt 4, Bild 1 von 2 Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the top and bottom screws: Schritt 4, Bild 2 von 2
    • Use a JIS 00 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
    • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
    Frag FixBot
  5. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the center side screws: Schritt 5, Bild 1 von 2 Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the center side screws: Schritt 5, Bild 2 von 2
    • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
    Frag FixBot
  6. Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 6, Bild 1 von 2 Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 6, Bild 2 von 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
    Frag FixBot
  7. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the kickstand well screw: Schritt 7, Bild 1 von 1
    • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
    Frag FixBot
  8. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the rear panel: Schritt 8, Bild 1 von 3 Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the rear panel: Schritt 8, Bild 2 von 3 Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the rear panel: Schritt 8, Bild 3 von 3
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel straight up from the bottom of the device and remove it.
    • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
    Frag FixBot
  9. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the microSD card reader: Schritt 9, Bild 1 von 1
    • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
    Frag FixBot
  10. Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 10, Bild 1 von 2 Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 10, Bild 2 von 2
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
    Frag FixBot
  11. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the shield plate: Schritt 11, Bild 1 von 1
    • Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
    Frag FixBot
  12. Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 12, Bild 1 von 2 Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 12, Bild 2 von 2
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
    Frag FixBot
  13. Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 13, Bild 1 von 3 Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 13, Bild 2 von 3 Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 13, Bild 3 von 3
    iFixit Thermal Putty
    $9.95
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • You can reuse the pink thermal compound if you're careful. Keep the compound clean and make sure it makes solid contact between the heat sink and the shield during reassembly.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
    Frag FixBot
  14. Nintendo Switch Headphone Jack and Game Card Board Replacement, Disconnect the battery: Schritt 14, Bild 1 von 2 Nintendo Switch Headphone Jack and Game Card Board Replacement, Disconnect the battery: Schritt 14, Bild 2 von 2
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    Frag FixBot
  15. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the heat sink: Schritt 15, Bild 1 von 1
    • Use a JIS 00 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    Frag FixBot
    • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    • The foam is really delicate and tears easily. Use the following technique to peel the foam:
    • Insert the point of a spudger underneath the part of the foam that isn't stuck against anything,
    • Press the top of the foam with your finger to hold it in place.
    • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
    Frag FixBot
  16. Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 17, Bild 1 von 3 Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 17, Bild 2 von 3 Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 17, Bild 3 von 3
    • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
    Frag FixBot
  17. Nintendo Switch Headphone Jack and Game Card Board Replacement, Headphone Jack and Game Card Board: Schritt 18, Bild 1 von 1
    • Remove the two 3.1 mm Phillips screws from the headphone jack bracket.
    Frag FixBot
  18. Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 19, Bild 1 von 2 Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 19, Bild 2 von 2
    • Remove the headphone jack bracket.
    Frag FixBot
  19. Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 20, Bild 1 von 2 Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 20, Bild 2 von 2
    • Use a spudger to lift the black locking flap on the ZIF connector up.
    • To reconnect ZIF connectors like this one, gently slide the cable back in place and press the locking flap back into place.
    Frag FixBot
  20. Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 21, Bild 1 von 2 Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 21, Bild 2 von 2
    • Use the pointed end of a spudger to slide the ribbon cable out of the ZIF connector.
    Frag FixBot
  21. Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 22, Bild 1 von 1
    • Remove the single 3.1 mm Phillips screw from the headphone jack and game card board.
    Frag FixBot
  22. Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 23, Bild 1 von 2 Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 23, Bild 2 von 2
    • Use the flat end of a spudger to pry the headphone jack press-fit connector straight up off the motherboard.
    Frag FixBot
  23. Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 24, Bild 1 von 2 Nintendo Switch Headphone Jack and Game Card Board Replacement: Schritt 24, Bild 2 von 2
    • Remove the headphone jack and game card board.
    Frag FixBot
Abschluss
Blake Klein
74.872 Reputation
50 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 28
Insgesamt: 196
