Einleitung
Follow this guide to replace the heat sink on a Nintendo Switch gaming console.
Installation will require the thermal paste to be cleaned off and replaced with new.
  1. Remove the four 6.3mm Tri-point Y00 screws from the rear panel.
    • Remove the four 6.3mm Tri-point Y00 screws from the rear panel.
  2. Remove the single 6.1mm JIS #000 screw from underneath the kickstand.
    • Remove the single 6.1mm JIS #000 screw from underneath the kickstand.
  3. Remove the two 2.7mm JIS #000 screws from the bottom of the device.
    • Remove the two 2.7mm JIS #000 screws from the bottom of the device.
  4. Remove the single 2.7mm JIS #000 screw from the top of the device.
    • Remove the single 2.7mm JIS #000 screw from the top of the device.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Remove the single 3.8mm JIS #0 screw from the right Joy-Con rail. Remove the single 3.8mm JIS #0 screw from the left Joy-Con rail.
    • Remove the single 3.8mm JIS #0 screw from the right Joy-Con rail.
    • Remove the single 3.8mm JIS #0 screw from the left Joy-Con rail.
  7. Pull the rear panel up and off of the device. Pull the rear panel up and off of the device. Pull the rear panel up and off of the device.
    • Pull the rear panel up and off of the device.
  8. Remove the six 3.1mm JIS #000 screws from the shield plate.
    • Remove the six 3.1mm JIS #000 screws from the shield plate.
  9. Remove the shield plate from the device. Remove the shield plate from the device.
    • Remove the shield plate from the device.
  10. Insert the pointed end of a spudger underneath the white connector and pry upwards to disconnect the battery from the motherboard. Insert the pointed end of a spudger underneath the white connector and pry upwards to disconnect the battery from the motherboard.
    • Insert the pointed end of a spudger underneath the white connector and pry upwards to disconnect the battery from the motherboard.
  11. Remove the three 3.1mm JIS #000 screws from the heatsink.
    • Remove the three 3.1mm JIS #000 screws from the heatsink.
  12. Pull the heatsink up 45 degrees and rotate it to the right to remove. Pull the heatsink up 45 degrees and rotate it to the right to remove. Pull the heatsink up 45 degrees and rotate it to the right to remove.
    • Pull the heatsink up 45 degrees and rotate it to the right to remove.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Blake Klein
42.123 Reputation
48 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
108 Mitglieder
8.327 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 12
Letzte 7 Tage: 38
Letzte 30 Tage: 144
Insgesamt: 687
