Einleitung
This guide will help you remove the front panel of the controller. It is a prerequisite guide only.
Was du brauchst
Pull down on the battery cover release lever and pull back to remove the cover.
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
Carefully turn over the controller and place it on a flat surface.
Slowly separate the top panel from the bottom panel.
Once separated, set aside the top panel.
3 weitere Personen haben diese Anleitung absolviert.
