Einleitung
The motherboard is the central hub of all components and ports in your device. If multiple components and ports are not working properly, the motherboard in your device may not be functioning and may need replacement.
Please read all instructions in each step before continuing to disassemble and replace the motherboard.
Was du brauchst
Using the Phillips #0 screwdriver, remove the single screw from the bottom of the device.
Pull out the slot with the battery (pictured in the third photo). Leave both the battery and the slot organized on the side with the removed screw.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to remove the three black square stickers on the top of the console by prying under and gently pulling up to expose three screws.
Use the Phillips #0 screwdriver to unscrew all three of the 4.1mm screws underneath the rubber feet.
Leave the screws in their holes and remove this plate.
Remove the two 5.9 mm screws using the Phillips #0 screwdriver.
Remove the two 8.3mm screws using the Y1 Tri-point screwdriver.
Remove the two half-cylinder stickers from the back left side of the Wii using the spudger.
Remove the two rectangular size stickers closest to the front of the Wii using the tweezers. Ignore the other two half-cylinder stickers.
Use the Y1 Tri-point screwdriver to remove all four Y screws on the left facing side of the console.
On the bottom of the console, use the spudger tool to remove the one square rubber pad.
Then use tweezers to take off three flat square stickers covering screws.
Use the Phillips #0 screwdriver to remove three screws.
Use the Y1 Tri-point screwdriver to remove two screws.
Carefully pull off the front cover (the one with the disc drive hole). You will expose a red and black wire.
Pinch the red and black wire at the same time and pull perpendicular to the port. The wire will come out of the port.
After removing the front cover, evenly pull from each corner to pull apart the left side and right side of the case.
For the wide, flat wire on the left of the other wire, flip up the wire holding lock and then carefully pull away parallel to the disc drive.
For the multiple wires on the right side of the wide wire, just pull away parallel to the disc drive to remove.
Remove the three 10mm screws using the Phillips #0 screwdriver.
Lift the plastic piece and remove it from the device.
Remove the four black 10 mm screws attached to the black plastic frames using the Phillips #0 screwdriver.
After removing all silver and 10 mm black screws attached to the console frame, remove the fan by pinching the grey and black wires at the same time. Detach the wires from the port.
Using a Phillips #0 screwdriver, remove the four 11.3 mm Phillips screws attaching the heatsink to the case frame and motherboard.
Pull off the heatsink and place carefully on a dry surface.
Once the heatsink is removed, cautiously pull the motherboard out from the left side of the console case and remove it from the device.
Using your fingers, gently detach the Wi-Fi board from the motherboard.
Using your fingers, gently lift and remove the bluetooth module from the motherboard.
Pull the power supply cable parallel to the motherboard and disconnect it from the device.
Flip up the long flat lever for the optical drive reader cable and pull away the cable.
Eine weitere Person hat diese Anleitung absolviert.
