Zum Hauptinhalt wechseln
Nintendo Wii Remote Disassembly and Corrosion Cleaning
Was du brauchst
  1. Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 1, Bild 1 von 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 1, Bild 2 von 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 1, Bild 3 von 3
    • Remove the battery cover and the batteries.
    • Remove the four tri-point Y1 screws holding the remote together.
  2. Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 2, Bild 1 von 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 2, Bild 2 von 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 2, Bild 3 von 3
    • Using an opening tool, apply pressure to the tabs located near the "A" button.
    • The tabs can break, but the remote will still work even if they do break.
    • Remove the faceplate.
  3. Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 3, Bild 1 von 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 3, Bild 2 von 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 3, Bild 3 von 3
    • To remove the motherboard, press up on the "B" button, and then the connector at the bottom.
  4. Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 4, Bild 1 von 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 4, Bild 2 von 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 4, Bild 3 von 3
    • Unclip the tabs to remove the plastic piece.
    • On the back, move the vibration motor out of the way to completely remove the plastic piece.
  5. Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 5, Bild 1 von 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 5, Bild 2 von 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 5, Bild 3 von 3
    • Find any corrosion on the motherboard.
    • Corrosion on the motherboard will have a blueish color and may appear in multiple places.
    • Check the battery terminals for corrosion.
    • If batteries leaked in the remote, there will be corrosion on the terminals.
  6. Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 6, Bild 1 von 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 6, Bild 2 von 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 6, Bild 3 von 3
    • Clean the corroded areas with isopropyl alcohol and a toothbrush.
    • Q-tips can be used instead of a toothbrush.
    • Cleaning won't make look it perfect, but the remote will work again.
  7. Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 7, Bild 1 von 2 Nintendo Wii Remote Disassembly and Corrosion Cleaning: Schritt 7, Bild 2 von 2
    • Clean the terminals with isopropyl alcohol and a toothbrush or Q-tips.
    • It is difficult to remove this piece, so clean it as good as you can. Using more isopropyl alcohol helps here.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Would 99% Isopropyl Alcohol also be okay to use as cleaner?
Mirela - Antwort
Of course, I use this for cleaning every type of motherboard, the difference between 99% and 70% is that the solution contains less water, so the liquid evaporate in less time :)
ReDeath_ -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 23
Letzte 7 Tage: 252
Letzte 30 Tage: 969
Insgesamt: 20,027
