Zum Hauptinhalt wechseln
Nintendo Wii U Button Replacement
Was du brauchst
  1. Nintendo Wii U Button Replacement, Button Replacement: Schritt 1, Bild 1 von 2 Nintendo Wii U Button Replacement, Button Replacement: Schritt 1, Bild 2 von 2
    • You will first need to find all the screws hidden underneath the black (or white) square stickers. They are all located on the bottom side of the Wii U.
    • Use a spudger to remove the stickers if it is difficult to peel off with your fingers.
  2. Nintendo Wii U Button Replacement: Schritt 2, Bild 1 von 1
    • Remove the five Phillips #0 screws.
    • Remove the four Tri-Wing Y1 screws.
  3. Nintendo Wii U Button Replacement: Schritt 3, Bild 1 von 2 Nintendo Wii U Button Replacement: Schritt 3, Bild 2 von 2
    • Remove the CMOS battery door on the left side of the console.
    • Once the door is removed, remove the three Phillips #0 screws.
  4. Nintendo Wii U Button Replacement: Schritt 4, Bild 1 von 3 Nintendo Wii U Button Replacement: Schritt 4, Bild 2 von 3 Nintendo Wii U Button Replacement: Schritt 4, Bild 3 von 3
    • Gently pry off the top lid of the Wii U.
  5. Nintendo Wii U Button Replacement: Schritt 5, Bild 1 von 3 Nintendo Wii U Button Replacement: Schritt 5, Bild 2 von 3 Nintendo Wii U Button Replacement: Schritt 5, Bild 3 von 3
    • Rotate the device so that the front plate is facing you.
    • Remove the two Phillips #1 screws.
  6. Nintendo Wii U Button Replacement: Schritt 6, Bild 1 von 3 Nintendo Wii U Button Replacement: Schritt 6, Bild 2 von 3 Nintendo Wii U Button Replacement: Schritt 6, Bild 3 von 3
    • Remove the ribbon cable and separate the front plate from the main console.
  7. Nintendo Wii U Button Replacement: Schritt 7, Bild 1 von 1
    • Remove the three Phillips #1 screws.
  8. Nintendo Wii U Button Replacement: Schritt 8, Bild 1 von 1
    • Once unscrewed, remove the black braces that hold the power button, eject button, and sync button in place.
  9. Nintendo Wii U Button Replacement: Schritt 9, Bild 1 von 1
    • Remove the desired button(s).
Abschluss
Emily Vasquez
884 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 1-2, Leahy Spring 2016 Mitglied von USF Tampa, Team 1-2, Leahy Spring 2016
USFT-LEAHY-S16S1G2
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Anyone know what that ribbon cable is in step 6? Just regular 9 pin?
Lugi - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 22
Letzte 30 Tage: 86
Insgesamt: 4,507
