Zum Hauptinhalt wechseln
Nintendo Wii U Pro Controller D-Pad Replacement
Was du brauchst
  1. Nintendo Wii U Pro Controller D-Pad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller D-Pad Replacement: Schritt 2, Bild 1 von 2 Nintendo Wii U Pro Controller D-Pad Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller D-Pad Replacement, Joystick: Schritt 3, Bild 1 von 1
    • Remove the eight 5.5 mm Y0 screws.
  4. Nintendo Wii U Pro Controller D-Pad Replacement: Schritt 4, Bild 1 von 2 Nintendo Wii U Pro Controller D-Pad Replacement: Schritt 4, Bild 2 von 2
    • Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
    • If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
  5. Nintendo Wii U Pro Controller D-Pad Replacement: Schritt 5, Bild 1 von 1
    • Move the right trigger and sensor out of the way.
    • Remove the 4 mm JIS #0 screw.
  6. Nintendo Wii U Pro Controller D-Pad Replacement: Schritt 6, Bild 1 von 1
    • Move the left trigger and sensor out of the way.
  7. Nintendo Wii U Pro Controller D-Pad Replacement: Schritt 7, Bild 1 von 1
    • Remove the joysticks and motherboard from the controller’s shell.
  8. Nintendo Wii U Pro Controller D-Pad Replacement: Schritt 8, Bild 1 von 1
    • Carefully pull the rubber thumbsticks off of the electronic bearings to remove the joysticks.
  9. Nintendo Wii U Pro Controller D-Pad Replacement, D-Pad: Schritt 9, Bild 1 von 1
    • Locate the two 4 mm motherboard screws, shown circled in red, with the J0 screwdriver.
  10. Nintendo Wii U Pro Controller D-Pad Replacement: Schritt 10, Bild 1 von 1
    • Remove the motherboard and connected components. The rubber pad of the D-Pad is indicated in the image by the red arrow.
  11. Nintendo Wii U Pro Controller D-Pad Replacement: Schritt 11, Bild 1 von 1
    • Remove the rubber pad and D-Pad button. The D-Pad can be replaced by the new D-Pad or be cleaned to improve condition.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Jesse Burton
586 Reputation
3 Anleitungen geschrieben
IUPUI, Team 2-2, Harley Fall 2015 Mitglied von IUPUI, Team 2-2, Harley Fall 2015
IUPUI-HARLEY-F15S2G2
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 40
Insgesamt: 4,523
