Einleitung
This guide details the replacement of the motherboard on a Nintendo Wii Mini. The steps shown in the images are of the disassembly process, and the replacement and reassembly are as simple as completing the steps in reverse.
An electrostatic discharge bracelet is recommended when handing delicate electronics.
A motherboard replacement may be necessary when these symptoms occur in your Wii Mini : Wii does not turn on or will not boot up after power supply is found to be working.
Was du brauchst
Remove the two rubber feet at the back of the console to reveal the hidden screws.
Remove the four 6mm Phillips #0 screws.
Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
Gently lift the top piece of the console and set it aside.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Turn the Wii mini around so that the back of the device is facing you.
Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece.
Using your fingers, gently pull the top of the pin connector straight up to detach the fan from the console.
Remove the fan piece and set it aside.
Using your fingers, slide out the blue ribbon cable from the the top of the power board.
Using a Phillips #0 Screwdriver, unscrew the two 4mm screws at the top and bottom of the power board.
Using your fingers, gently pull the pin connector to disconnect the power board from the disc drive.
Using a Phillips #0 Screwdriver, unscrew the 6 mm screw at the top of the black tray.
Using your fingers, pull the black plastic tray toward you to loosen it from the console.
Make sure the black square pieces are separated from the metal square pieces before trying to lift out the tray.
Once separated, lift the plastic tray out of the console and set it aside.
Using a Phillips #0 screwdriver, remove the eleven 5 mm screws holding the silver metal plate to the console.
10 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Can you fit a Wii Motherboard inside this casing, and use the dvd drive, if so I have a few wiis with broken DVD drives I would like to repair and this would be a cheap solution.
