Einleitung
Follow this guide to remove the upper case of your Nintendo Wii mini.
Prerequisite-only.
Was du brauchst
Remove the two rubber feet at the back of the console to reveal the hidden screws.
Remove the four 6mm Phillips #0 screws.
Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
Gently lift the top piece of the console and set it aside.
Fast fertig!
Abschluss
