Einleitung
In this guide, I will demonstrate how to fix a faulty power window switch on a 2005 Nissan Frontier (King Cab). I did this after the driver-side switch for controlling the passenger window did not work. After further inspection of the switch circuit board, I noticed that the electrical contacts were dirty. After the electrical contacts and reinstalling, the windows worked again.
Was du brauchst
Insert the first trim tool on the right side of the button molding.
Insert the second trim tool on the left, and shimmy it open.
Pry the marked latches off on both sides to remove the molding around the button assembly.
Insert the U-shaped trim tool under the right latch.
Insert the narrow-ended trim tool between the two latches on the left.
Shimmy it open and repeat the process for the other side, separating the black housing from the rear casing and exposing the circuit board.
Using a thin spudger, carefully pry these two latches off of the lever.
Carefully wiggle the lever off, and remove the small metal parts from under the lever. These parts are moving electrical contacts.
Clean each of the six contacts shown with cotton-swabs soaked in isopropyl alcohol.
Clean the other contacts for the:
Driver-window power switch
Vehicle lock switch
Place the moving electrical contacts back into its housing as shown.
Snap the lever back onto its housing.
Place this moving electrical contact onto the vehicle lock lever.
Ensure this nub sticks out this way.
These parts will be fastened to the driver window lever.
Press the guide (the bigger part) onto the driver-window lever as shown.
Position the moving contacts onto the guide as shown.
Ensure the assembly works by carefully pushing and pulling the buttons. It should move like this.
Position the circuit board over the housing, as shown.
Lower the circuit board and press it down.
Snap the Rear Shielding back into place, as shown.
Test all the buttons, make sure that they are not jammed.
Once the power window switch assembly has been rebuilt, simply use steps 3 to 1 to help you reinstall the switches.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
Nice guide, I was able to fix a window and lock issue with a simple cleaning thanks to these well-done instructions. Thanks
very helpful. thank you
I cleaned my entire assembly and my window is still stuck in my door. Switches won't work. Any chance there's a fix for the regulator wiring? I know it isn't broken. My window works just not how it's supposed to. Somehow it's doing opposite day while pressing it to go up? Highly confused?
