Zum Hauptinhalt wechseln
Nissan Versa Note Media Display System Replacement
Was du brauchst
  1. Nissan Versa Note Media Display System Replacement, Media Display System: Schritt 1, Bild 1 von 1
    • Ensure that the car is turned off.
  2. Nissan Versa Note Media Display System Replacement: Schritt 2, Bild 1 von 1
    • Pull on the switch for indoor/outdoor air to remove it.
  3. Nissan Versa Note Media Display System Replacement: Schritt 3, Bild 1 von 2 Nissan Versa Note Media Display System Replacement: Schritt 3, Bild 2 von 2
    • Use a spudger (or an old credit card) to gently pry the front panel away from the rest of the dash.
    • After wedging the parts apart you will see a gap.
  4. Nissan Versa Note Media Display System Replacement: Schritt 4, Bild 1 von 3 Nissan Versa Note Media Display System Replacement: Schritt 4, Bild 2 von 3 Nissan Versa Note Media Display System Replacement: Schritt 4, Bild 3 von 3
    • Using your fingers, start from the top of the panel and move down on either side to pry the panel open.
  5. Nissan Versa Note Media Display System Replacement: Schritt 5, Bild 1 von 2 Nissan Versa Note Media Display System Replacement: Schritt 5, Bild 2 von 2
    • Once the panel is free from the dash, flip it over to expose the cables connected to it.
  6. Nissan Versa Note Media Display System Replacement: Schritt 6, Bild 1 von 3 Nissan Versa Note Media Display System Replacement: Schritt 6, Bild 2 von 3 Nissan Versa Note Media Display System Replacement: Schritt 6, Bild 3 von 3
    • Remove the top cable by simply squeezing the end and pulling it out of its socket.
    • Use a spudger to push down on the tab of the bottom cable and remove it.
  7. Nissan Versa Note Media Display System Replacement: Schritt 7, Bild 1 von 3 Nissan Versa Note Media Display System Replacement: Schritt 7, Bild 2 von 3 Nissan Versa Note Media Display System Replacement: Schritt 7, Bild 3 von 3
    • The front panel is now completely free from the dash and can be set aside.
    • Using a Phillips #3 screwdriver, remove the two screws on either side of the media system.
  8. Nissan Versa Note Media Display System Replacement: Schritt 8, Bild 1 von 2 Nissan Versa Note Media Display System Replacement: Schritt 8, Bild 2 von 2
    • Carefully pull out the media system and turn it over so that the cables on its rear are visible.
    • Use your hands to pinch the tabs and gently pull out each cable.
  9. Nissan Versa Note Media Display System Replacement: Schritt 9, Bild 1 von 3 Nissan Versa Note Media Display System Replacement: Schritt 9, Bild 2 von 3 Nissan Versa Note Media Display System Replacement: Schritt 9, Bild 3 von 3
    • Now the media system is completely free from the car.
    • Using a T10 Torx screwdriver, unscrew the four screws on either side of the media system.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
York University, Team S2-G5, Melo-Thaiss Fall 2020 Mitglied von York University, Team S2-G5, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S2G5
1 Mitglied
1 Anleitung geschrieben
Ein Kommentar
Muy ilustrativo y de muchá ayuda, gracias
Juanmanuel - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 57
Letzte 30 Tage: 92
Insgesamt: 4,206
