Einleitung
Use this guide to change the case of a microlight.
Was du brauchst
Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
Repeat this step for the bottom remaining battery.
Place the plastic opening tool below the LED lamp and push away from the device until you hear a click.
Continue to remove the LED lamp the with your fingers.
Place the plastic opening tool behind the logic board and bend away from the casing
Eine weitere Person hat diese Anleitung absolviert.
