Zum Hauptinhalt wechseln
Nixon Mission Android Wear Battery Replacement
Was du brauchst
  1. Nixon Mission Android Wear Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
  2. Nixon Mission Android Wear Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the back plate of watch.
  3. Nixon Mission Android Wear Battery Replacement: Schritt 3, Bild 1 von 1
    • Unclip 5 latches from motherboard using a plastic spudger.
  4. Nixon Mission Android Wear Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the 2 3.0mm screws from motherboard using PH00 Phillips head.
  5. Nixon Mission Android Wear Battery Replacement: Schritt 5, Bild 1 von 1
    • Carefully remove motherboard & internal screen.
  6. Nixon Mission Android Wear Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove from the motherboard the connector with the four cables.
    • Pull the cables upward and the motherboard downward as shown in the picture.
  7. Nixon Mission Android Wear Battery Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the battery from the watch.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
IUPUI, Team S3-G2, Harley Fall 2017 Mitglied von IUPUI, Team S3-G2, Harley Fall 2017
IUPUI-HARLEY-F17S3G2
3 Mitglieder
3 Anleitungen geschrieben
18 Kommentare
Hi, would you be able to advise where to purchase a replacement battery?
Simon Seow - Antwort
same here, where to purchase a replacement battery ?
peter.erdogyaraki - Antwort
Thank you for your tuto.
But now, where I can purchase a new battery?
Thank you
COUTURIER - Antwort
Hi! Anyone knows where to buy a new battery?
cristian.carvelli - Antwort
After an extensive search there doesn't seem to be any info out there about battery size…..still
Jerry Jerry J - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 51
Insgesamt: 6,262
