Einleitung
Batteries tend to lose capacity over time. This guide will show you how to replace the battery of your Nixon Mission Android Wear.
Was du brauchst
Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
Remove from the motherboard the connector with the four cables.
Pull the cables upward and the motherboard downward as shown in the picture.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
18 Kommentare
Hi, would you be able to advise where to purchase a replacement battery?
same here, where to purchase a replacement battery ?
Hi! Anyone knows where to buy a new battery?
After an extensive search there doesn't seem to be any info out there about battery size…..still
