Zum Hauptinhalt wechseln
Nobis NB09 Battery Replacement
Was du brauchst
  1. Nobis NB09 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before beginning this process, make sure the device is powered off.
    • Remove the screws holding the case together.
  2. Nobis NB09 Battery Replacement: Schritt 2, Bild 1 von 3 Nobis NB09 Battery Replacement: Schritt 2, Bild 2 von 3 Nobis NB09 Battery Replacement: Schritt 2, Bild 3 von 3
    • Use an opening tool to loosen and pry off the pink back plate.
  3. Nobis NB09 Battery Replacement: Schritt 3, Bild 1 von 2 Nobis NB09 Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the black electronic tape covering the circuit board.
  4. Nobis NB09 Battery Replacement: Schritt 4, Bild 1 von 1
    • Use the soldering iron to remove the black and red wires from the circuit board.
    • The black wire is the ground and the red wire is the battery positive terminal.
    • To reassemble, use the soldering iron to solder the leads at the end of the black (-) and red (+) wires from the new battery onto the proper terminals on the circuit board.
  5. Nobis NB09 Battery Replacement: Schritt 5, Bild 1 von 2 Nobis NB09 Battery Replacement: Schritt 5, Bild 2 von 2
    • Gently loosen the adhesive under the battery to avoid damaging it.
    • Use caution; the battery is soft and will bend very easily.
    • Dispose of the old battery properly at an electronic waste center or verified battery recycling store.
    • When reassembling, apply adhesive to the back of the new battery.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 7-1, Cichon Spring 2015 Mitglied von UMass Dartmouth, Team 7-1, Cichon Spring 2015
UMASSD-CICHON-S15S7G1
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
where can i buy a battery from
Frederick Shipman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 2,973
