Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Follow this guide to replace or change the colored lens inside of your Nokero N222-Huron in order to adapt the solar light to various situations.
  1. Grasp the clear cover and the white housing and twist the cover counter-clockwise.
    • Grasp the clear cover and the white housing and twist the cover counter-clockwise.
    • The lid may hold fast, but it will come off with some firm twisting.
  2. Lift the lid from the device
    • Lift the lid from the device
    • It may be helpful to use a spudger to pry under the lid if there is difficulty in getting a good grip on the smooth plastic.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. Turn the lens until the slots line up with the retaining clips on the device. Lift the lens off of the device. It should come off easily. Lift the lens off of the device. It should come off easily.
    • Turn the lens until the slots line up with the retaining clips on the device.
    • Lift the lens off of the device. It should come off easily.
  5. When reinstalling the lends, line up the slots of the new lens with the retaining clips, and rotate the lens counter-clockwise. You will hear an audible click when the lens is locked in place.
    • When reinstalling the lends, line up the slots of the new lens with the retaining clips, and rotate the lens counter-clockwise.
    • You will hear an audible click when the lens is locked in place.
Abschluss
To reassemble your device, follow the instructions for the first two steps in reverse order.
Vinny Capone
549 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 Mitglied von UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G4
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 168
