Einleitung
Follow this guide to mount your light in to the wall or ceiling and illuminate your work- or living- space.
Was du brauchst
Place the mounting bracket in the desired location and mark the center location. This is where the screw will be placed.
Place the screw through the bracket, as shown, and screw it into the marked or drilled location.
Make sure the bracket is facing in the desired direction before tightening the screw.
To remove or change the fixed mount for your device, follow these instructions in reverse order.
