Einleitung
This guide will teach you how to safely cut wires to remove the LED light panel component from the rest of the device and replace it with a new one.
Was du brauchst
Press down firmly to remove the battery cover and display battery.
Then remove the battery.
Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
Unlatch the clips on the inside and pull device apart.
With the back cover of the device removed, lightly pull up on the LED assembly to lift it out of its housing.
The LED assembly will separate into three components; the light board, outer housing, and plastic lens.
Set the outer housing and plastic lens aside.
Take a pair of pliers and cut the red and black wires connected to the light board.
Eine weitere Person hat diese Anleitung absolviert.
