Zum Hauptinhalt wechseln
Nokia 1010 Motherboard Replacement
Was du brauchst
  1. Nokia 1010 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Nokia 1010 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using your thumbs, press and slide down the back cover of the Nokia 1010.
  2. Nokia 1010 Motherboard Replacement: Schritt 2, Bild 1 von 3 Nokia 1010 Motherboard Replacement: Schritt 2, Bild 2 von 3 Nokia 1010 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Insert the prying tool in the notch above the battery.
    • Once the prying tool is inserted, lift up the battery.
  3. Nokia 1010 Motherboard Replacement, Faceplate: Schritt 3, Bild 1 von 2 Nokia 1010 Motherboard Replacement, Faceplate: Schritt 3, Bild 2 von 2
    • Insert the prying tool between the seam of the faceplate and the body.
  4. Nokia 1010 Motherboard Replacement: Schritt 4, Bild 1 von 3 Nokia 1010 Motherboard Replacement: Schritt 4, Bild 2 von 3 Nokia 1010 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Starting from the bottom of the phone, begin prying around the base of the phone alternating form left to right.
  5. Nokia 1010 Motherboard Replacement: Schritt 5, Bild 1 von 3 Nokia 1010 Motherboard Replacement: Schritt 5, Bild 2 von 3 Nokia 1010 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • As the base loosens, slowly increase the separation between the plates and the body of the phone.
  6. Nokia 1010 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 3 Nokia 1010 Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 3 Nokia 1010 Motherboard Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Using the spudger, pry back three tabs located on the left edge and three tabs located on the right edge of the body.
  7. Nokia 1010 Motherboard Replacement: Schritt 7, Bild 1 von 3 Nokia 1010 Motherboard Replacement: Schritt 7, Bild 2 von 3 Nokia 1010 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Once detached, lift and remove the faceplate from the motherboard.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 39
Insgesamt: 2,189
