Einleitung
If you are looking to add more memory to your Nokia 1010 this guide will show you how to access your SIM Card slot to add a SIM Card. This guide can also help you to find out where your SIM Card slot is if you want to take the SIM card out to transport your data on your SIM card somewhere else.
Was du brauchst
Using your thumbs, press and slide down the back cover of the Nokia 1010.
Insert the prying tool in the notch above the battery.
Once the prying tool is inserted, lift up the battery.
With your finger, remove the SIM card.
At this point the SIM card has nothing holding it in and the phone can be turned over allowing the SIM card to fall out.]
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
contact@davidmarsh.org.uk
what is the name or model or size of the SIM card please?
