Einleitung
This guide will lead you through the steps needed to remove the keypad in your phone.
Was du brauchst
Firmly grip the back of the casing.
Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
Using the flat end of the spudger, push out the 4 rubber tabs on the back of the keypad to remove it.
3 weitere Personen haben diese Anleitung absolviert.
