Einleitung
This guide will show you how to install a new motherboard and keyboard unit in your phone.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Flip the phone over so that the screen faces down. Press the gray button on the battery cover and slide it down off the back of the phone.
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Remove the six 6mm T6 Torx screws around the edge of the front of the phone. Remove the metal frame holding the screen and speaker.
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
  5. Gently lift motherboard unit out of the case. The motherboard and keyboard are one unit and are replaced together.
    • Gently lift motherboard unit out of the case.
    • The motherboard and keyboard are one unit and are replaced together.
Abschluss
11 weitere Nutzer haben diese Anleitung absolviert.
James Szelenyi
229 Reputation
1 Anleitung geschrieben
Cal Poly, Team 10-43, Amido Spring 2013 Mitglied von Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
4 Mitglieder
14 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 24
Insgesamt: 3,236
