Zum Hauptinhalt wechseln
Nokia 1100b RH-36 Motherboard and Keyboard Replacement
Was du brauchst
  1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: Schritt 1, Bild 1 von 2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: Schritt 1, Bild 2 von 2
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery: Schritt 2, Bild 1 von 1
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: Schritt 3, Bild 1 von 2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: Schritt 3, Bild 2 von 2
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
  4. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: Schritt 4, Bild 1 von 2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: Schritt 4, Bild 2 von 2
    • Gently lift motherboard unit out of the case.
    • The motherboard and keyboard are one unit and are replaced together.
Abschluss
13 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 10-43, Amido Spring 2013 Mitglied von Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
4 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
you nokia 1100 mother board please soon date…?
ajay gupta - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 4,537
