Zum Hauptinhalt wechseln
Nokia 2115i Faceplate Replacement
Was du brauchst
  1. Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: Schritt 1, Bild 1 von 3 Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: Schritt 1, Bild 2 von 3 Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: Schritt 1, Bild 3 von 3
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
  2. Nokia 2115i Faceplate Replacement: Schritt 2, Bild 1 von 2 Nokia 2115i Faceplate Replacement: Schritt 2, Bild 2 von 2
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
  3. Nokia 2115i Faceplate Replacement, Faceplate: Schritt 3, Bild 1 von 3 Nokia 2115i Faceplate Replacement, Faceplate: Schritt 3, Bild 2 von 3 Nokia 2115i Faceplate Replacement, Faceplate: Schritt 3, Bild 3 von 3
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
Abschluss
Shane
80 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 14-38, Forte Fall 2010 Mitglied von Cal Poly, Team 14-38, Forte Fall 2010
CPSU-FORTE-F10S14G38
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,548
