Ersatzteile
Kein Ersatzteil erforderlich.
Be sure cell phone is off before you begin to disassemble the phone. Press the button on the bottom of the back of the cell phone. Slide rear panel down and remove  it.
  • Be sure cell phone is off before you begin to disassemble the phone.
  • Press the button on the bottom of the back of the cell phone.
  • Slide rear panel down and remove it.
Kommentar hinzufügen
Using your fingernail, pry the back of the battery upwards and pull out. Using your fingernail, pry the back of the battery upwards and pull out. Using your fingernail, pry the back of the battery upwards and pull out.
  • Using your fingernail, pry the back of the battery upwards and pull out.
Insert the plastic opening tool under the faceplate. Separate the faceplate from main body by twisting the prying tool with some force. The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  • Insert the plastic opening tool under the faceplate.
  • Separate the faceplate from main body by twisting the prying tool with some force.
  • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
With the faceplate removed, simply peel off rubber key pad and remove. With the faceplate removed, simply peel off rubber key pad and remove. With the faceplate removed, simply peel off rubber key pad and remove.
  • With the faceplate removed, simply peel off rubber key pad and remove.
Locate and remove the six screws on the front of the phone using a T6 Torx. All 6 screws are 6.9mm long. All 6 screws are 6.9mm long.
  • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
After removing screws, lift the motherboard assembly straight off the cell phone body. After removing screws, lift the motherboard assembly straight off the cell phone body. After removing screws, lift the motherboard assembly straight off the cell phone body.
  • After removing screws, lift the motherboard assembly straight off the cell phone body.
Locate the two plastic LCD unit hooks. Pry hooks outward. Pry hooks outward.
  • Locate the two plastic LCD unit hooks.
  • Pry hooks outward.
Gently pull LCD unit away from the logic board. Be careful not to damage the connection on the top, right hand side of the logic board. Be careful not to damage the connection on the top, right hand side of the logic board.
  • Gently pull LCD unit away from the logic board.
    • Be careful not to damage the connection on the top, right hand side of the logic board.
With the LCD unit removed, gently press out the speaker with a non-metallic pointed object. With the LCD unit removed, gently press out the speaker with a non-metallic pointed object. With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
  • With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
Abschluss
Andres Echeverria
Mitglied seit 29.10.2010
1 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 20-8, Maness Fall 2010 Mitglied von Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Mitglieder
28 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 186
