Zum Hauptinhalt wechseln
Nokia 2128i Power Unit Replacement
Was du brauchst
  1. Nokia 2128i Power Unit Replacement, Battery: Schritt 1, Bild 1 von 3 Nokia 2128i Power Unit Replacement, Battery: Schritt 1, Bild 2 von 3 Nokia 2128i Power Unit Replacement, Battery: Schritt 1, Bild 3 von 3
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Nokia 2128i Power Unit Replacement: Schritt 2, Bild 1 von 3 Nokia 2128i Power Unit Replacement: Schritt 2, Bild 2 von 3 Nokia 2128i Power Unit Replacement: Schritt 2, Bild 3 von 3
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Nokia 2128i Power Unit Replacement, Faceplate: Schritt 3, Bild 1 von 3 Nokia 2128i Power Unit Replacement, Faceplate: Schritt 3, Bild 2 von 3 Nokia 2128i Power Unit Replacement, Faceplate: Schritt 3, Bild 3 von 3
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. Nokia 2128i Power Unit Replacement, Keypad: Schritt 4, Bild 1 von 3 Nokia 2128i Power Unit Replacement, Keypad: Schritt 4, Bild 2 von 3 Nokia 2128i Power Unit Replacement, Keypad: Schritt 4, Bild 3 von 3
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Nokia 2128i Power Unit Replacement, Motherboard Assembly: Schritt 5, Bild 1 von 3 Nokia 2128i Power Unit Replacement, Motherboard Assembly: Schritt 5, Bild 2 von 3 Nokia 2128i Power Unit Replacement, Motherboard Assembly: Schritt 5, Bild 3 von 3
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  6. Nokia 2128i Power Unit Replacement: Schritt 6, Bild 1 von 3 Nokia 2128i Power Unit Replacement: Schritt 6, Bild 2 von 3 Nokia 2128i Power Unit Replacement: Schritt 6, Bild 3 von 3
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
  7. Nokia 2128i Power Unit Replacement, Power Button: Schritt 7, Bild 1 von 3 Nokia 2128i Power Unit Replacement, Power Button: Schritt 7, Bild 2 von 3 Nokia 2128i Power Unit Replacement, Power Button: Schritt 7, Bild 3 von 3
    • With the motherboard and LCD unit removed, gently pull the power button out of its housing.
  8. Nokia 2128i Power Unit Replacement, Power Unit: Schritt 8, Bild 1 von 3 Nokia 2128i Power Unit Replacement, Power Unit: Schritt 8, Bild 2 von 3 Nokia 2128i Power Unit Replacement, Power Unit: Schritt 8, Bild 3 von 3
    • Flip phone over and find the sticker that holds the metallic plating together with the phone's case.
    • Pry off the portion of the sticker that is attached to the phone's case. Do not worry about removing the sticker from the metallic plate.
  9. Nokia 2128i Power Unit Replacement: Schritt 9, Bild 1 von 3 Nokia 2128i Power Unit Replacement: Schritt 9, Bild 2 von 3 Nokia 2128i Power Unit Replacement: Schritt 9, Bild 3 von 3
    • Locate the small hook that holds the metallic plate and phone case together on the front side of the phone
    • Place your thumbs on the backside of the metallic plate.
    • Stretch phone casing outward to detach hook from metallic plating. Simultaneously push metallic plate outward to remove.
  10. Nokia 2128i Power Unit Replacement: Schritt 10, Bild 1 von 3 Nokia 2128i Power Unit Replacement: Schritt 10, Bild 2 von 3 Nokia 2128i Power Unit Replacement: Schritt 10, Bild 3 von 3
    • Pry out the power unit once the metallic plate has been removed.
  11. Nokia 2128i Power Unit Replacement: Schritt 11, Bild 1 von 1
    • Be sure to place the power unit back into the phone's case with the gold hardware pointing upward.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 20-8, Maness Fall 2010 Mitglied von Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 15
Insgesamt: 645
