Einleitung
If the phone's vibration system is not working properly, changing the vibrator is a breeze following these simple steps.
Was du brauchst
Be sure cell phone is off before you begin to disassemble the phone.
Press the button on the bottom of the back of the cell phone.
Slide rear panel down and remove it.
Insert the plastic opening tool under the faceplate.
Separate the faceplate from main body by twisting the prying tool with some force.
The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
Locate and remove the six screws on the front of the phone using a T6 Torx.
All 6 screws are 6.9mm long.
After removing screws, lift the motherboard assembly straight off the cell phone body.
With the logic board and LCD unit removed, gently pry out the vibrator from its housing.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
