Zum Hauptinhalt wechseln
Nokia 2128i Vibrator Replacement
Was du brauchst
  1. Nokia 2128i Vibrator Replacement, Battery: Schritt 1, Bild 1 von 3 Nokia 2128i Vibrator Replacement, Battery: Schritt 1, Bild 2 von 3 Nokia 2128i Vibrator Replacement, Battery: Schritt 1, Bild 3 von 3
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Nokia 2128i Vibrator Replacement: Schritt 2, Bild 1 von 3 Nokia 2128i Vibrator Replacement: Schritt 2, Bild 2 von 3 Nokia 2128i Vibrator Replacement: Schritt 2, Bild 3 von 3
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Nokia 2128i Vibrator Replacement, Faceplate: Schritt 3, Bild 1 von 3 Nokia 2128i Vibrator Replacement, Faceplate: Schritt 3, Bild 2 von 3 Nokia 2128i Vibrator Replacement, Faceplate: Schritt 3, Bild 3 von 3
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. Nokia 2128i Vibrator Replacement, Keypad: Schritt 4, Bild 1 von 3 Nokia 2128i Vibrator Replacement, Keypad: Schritt 4, Bild 2 von 3 Nokia 2128i Vibrator Replacement, Keypad: Schritt 4, Bild 3 von 3
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Nokia 2128i Vibrator Replacement, Motherboard Assembly: Schritt 5, Bild 1 von 3 Nokia 2128i Vibrator Replacement, Motherboard Assembly: Schritt 5, Bild 2 von 3 Nokia 2128i Vibrator Replacement, Motherboard Assembly: Schritt 5, Bild 3 von 3
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  6. Nokia 2128i Vibrator Replacement: Schritt 6, Bild 1 von 3 Nokia 2128i Vibrator Replacement: Schritt 6, Bild 2 von 3 Nokia 2128i Vibrator Replacement: Schritt 6, Bild 3 von 3
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
  7. Nokia 2128i Vibrator Replacement, Vibrator: Schritt 7, Bild 1 von 2 Nokia 2128i Vibrator Replacement, Vibrator: Schritt 7, Bild 2 von 2
    • With the logic board and LCD unit removed, gently pry out the vibrator from its housing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Curtis Lutje
28 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 20-8, Maness Fall 2010 Mitglied von Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 2,151
