Zum Hauptinhalt wechseln
Einleitung
This guide shows you how to replace a front panel for the phone.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off. Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off. Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone. Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone. Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger. After removal, lower the metal sim card holder into its original position. After removal, lower the metal sim card holder into its original position.
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Insert the plastic opening tool into the crack between the front and back panels. Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Lift the bottom of the front cover away from the phone. Continue lifting until the top of the front cover is fully removed from the phone.
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Andrew Wood
336 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 7-52, Amido Fall 2010 Mitglied von Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 2,039
