Zum Hauptinhalt wechseln
Nokia 2610 Speaker Replacement
Was du brauchst
  1. Nokia 2610 Speaker Replacement, Battery and Sim Card: Schritt 1, Bild 1 von 3 Nokia 2610 Speaker Replacement, Battery and Sim Card: Schritt 1, Bild 2 von 3 Nokia 2610 Speaker Replacement, Battery and Sim Card: Schritt 1, Bild 3 von 3
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Speaker Replacement: Schritt 2, Bild 1 von 3 Nokia 2610 Speaker Replacement: Schritt 2, Bild 2 von 3 Nokia 2610 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Speaker Replacement: Schritt 3, Bild 1 von 3 Nokia 2610 Speaker Replacement: Schritt 3, Bild 2 von 3 Nokia 2610 Speaker Replacement: Schritt 3, Bild 3 von 3
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Nokia 2610 Speaker Replacement, Front Pannel: Schritt 4, Bild 1 von 2 Nokia 2610 Speaker Replacement, Front Pannel: Schritt 4, Bild 2 von 2
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Nokia 2610 Speaker Replacement: Schritt 5, Bild 1 von 2 Nokia 2610 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
  6. Nokia 2610 Speaker Replacement, Circuit Board: Schritt 6, Bild 1 von 1
    • Use the Torx screwdriver with the T6 attachmet to remove the 6 .4 mm screws around the outside of the circuit board.
    • Note: Removing the 4 T6 screws around the screen will loosen it, so don't worry if the screen also separates from the circuit board.
  7. Nokia 2610 Speaker Replacement: Schritt 7, Bild 1 von 3 Nokia 2610 Speaker Replacement: Schritt 7, Bild 2 von 3 Nokia 2610 Speaker Replacement: Schritt 7, Bild 3 von 3
    • Lift the circuit board out of the back cover.
  8. Nokia 2610 Speaker Replacement, Speaker: Schritt 8, Bild 1 von 3 Nokia 2610 Speaker Replacement, Speaker: Schritt 8, Bild 2 von 3 Nokia 2610 Speaker Replacement, Speaker: Schritt 8, Bild 3 von 3
    • Using the plastic opening tool, gently pry the speaker out of its slot in the back cover of the phone.
    • Note: The easiest way to remove the speaker is to insert the plastic opening tool in the upper right corner of the speaker.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 7-52, Amido Fall 2010 Mitglied von Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 2,648
